Creado por davock
15/04/2009 a las 1:51:09
cual es mejor...? Creado el 15/04/2009 a las 1:51:09
Schwinn Mesa Gs:
Specifications:
* Frame: NLitened Gold Label Custom Drawn Aluminum alloy Off-Road Ride-Tuned geometry, Zero Stack head tube, 3x gussets, sloping top tube, wishbone Epicenter seat stays, replaceable der. hanger, disc brake mount, rack and WB fittings.
* Fork: Rockshox J1, Aluminum lowers, Coil / MCU spring, pre-load adjust, and mini-boots, 100mm travel
* Crankset: TruVativ X-Flow alloy arms, 42-32-22 Cr-Mo rings
* Bottom Bracket: TruVativ sealed cartridge square taper 68 x 113 w/ chainline stabilizer
* Pedals: ATB Resin body, Boron steel axle, Steel cage. Toe-clip adaptable.
* Front Derailleur: SRAM 3.0 31.8 top pull
* Rear Derailleur: SRAM SX-5
* Shifters: SRAM SX-4 dual trigger control
* Freewheel: SRAM Power Glide 8-speed cassette 11-32
* Chain: Shimano CN-IG51
* Rims: Jalco double wall alloy w/ CNC "SSD" sidewalls to improve wet braking, 32H
* Tires: WTB 26" x 2.1" Velociraptor Front and Rear specific tread pattern.
* Front Hub: JY Alloy Weather Sealed w/ alloy QR
* Rear Hub: JY Alloy Weather Sealed Cassette 8-speed QR, 32H
* Spokes: Stainless steel 14 gauge
* Front Brake: Tektro Linear Pull w/ 64mm MC pads and linear springs
* Rear Brake: Tektro Linear Pull w/ 64mm MC pads and linear springs
* Brake Levers: Tektro all-alloy w/ forged lever and reach adjustment
* Handlebar: Schwinn 6061 T6. 32 mm Rise, 5 degree bend, 620 mm wide
* Stem: Schwinn Ride Tuned alloy threadless,10 degree rise with forged 4-bolt front load cap.
* Grips: Schwinn double density Kraton / Gel
* Headset: FPD Threadless semi-integrated Aheadset 1 1/8"
* Saddle: WTB Speed V Sport w/ Comfort Zone
* Seat Post: Forged Alloy Ride Tuned, micro adjust 26.8 x 350
* Seat Clamp: Alloy Low-Profile QR w/ forged clamp
Mongoose Tyax Comp Disc:
Specifications:
Seatpost: Alloy w/ Micro-Adjust head
Headset: FSA Zero Stack
Frame: Heat Treated Alloy MTB Design
Tires: Kenda Komodo Skinwall, 26 x 2.1"
Chain: KMC Z-72
Stem: Mongoose Alloy Threadless
Handlebar: Mongoose Alloy, 30mm rise, 31.8mm clamp
Grips/Tape: Mongoose Dual Density
Pedals: Mongoose Logo Alloy Platform
Rear Shock: NA
Brakes: ProMax Mechanical Disc, 160mm rotor
Levers: ProMax melt-forged, 2-finger
Wheelset: Rims: Jalco AX-430, Double Wall, 32H; Hubs: ProMax Disc compatible Alloy sealed mech w/ rear cassette
Front Derailleur: Shimano Acera FD-C050
Rear Derailleur: Shimano Acera RD-M340, 8-speed
Shifters: Shimano EF-50 EZ Fire 24-speed
Cassette: Shimano HG30, 11/32T, 8-speed
Crankset: Shimano M151, 170mm, 24/34/42T
Fork: SR Suntour XCM-MLO, 100mm travel, 30mm stanchions, Alloy legs, preload adjust, mechanical lockout
Bottom Bracket: Tange Sealed Cartridge
Saddle: WTB Speed V Sport w/ Mongoose logo
< < < < novatoooooooo ayuda para pillar una mtb
Necesito ayuda ¿talla bici 18 ó 20? > > > >
