Creado por jumbo323
14/02/2008 a las 22:49:32
Opinion bici nueva Creado el 14/02/2008 a las 22:49:32
14/02/2008 a las 22:54:21
Replicado el 14/02/2008 a las 22:54:21
Terrible maquinon
Cuadro:All new Stumpjumper FSR M5 manipulated alloy frame w/ ORE TT/DT, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm trave
Horquilla:Fox Float 120 RL, 120mm travel, rebound/compression adjust, lock out, alloy steerer
Amortiguador:Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.25x1.75
Ruedas:DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
Cubiertas:S-Works The Captain 26x2.0, 120 TPI, tubeless ready aramid bead, dual compound
Cambio:SRAM X-9, 9-speed, mid cage
Desviador:Shimano M581 LX, DMD, top swing, dual pull
Sistema de Cambio:SRAM X-7, aluminum 9-speed trigger
Bielas:Shimano A/A/S 2pc custom , 22S/32A/44A, 4 bolt 104/64mm
Cassette:Shimano HG-50, 9-speed, 11-34t
Pedales:Crank Brothers Smarty custom for Specialized
Sillín:Specialized XC MTB, hollow Cr-Mo rails, SL foam
Tija de Sillín:2015 butted alloy, two bolt non-setback, 30.9 x 350/400mm
Manillar:Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
Potencia: Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
Dirección: 1 1/8 threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
Frenos:Custom Avid Juicy 5 SL, hydraulic disc, 185 and 203mm rotor
Size S M L XL XXL
Seat Tube Length - Center to Top 406mm 445mm 483mm 533mm 584mm
Top Tube Length (Horizontal) 556mm 590mm 625mm 645mm 665mm
Top Tube Length (Actual) 563mm 594mm 632mm 653mm 668mm
Chainstay Length 420mm 420mm 420mm 420mm 420mm
Bottom Bracket Height - Low Setting 335mm 335mm 335mm 335mm 335mm
Seat Tube Angle (Actual) - Low Setting 71° 71° 71° 71° 71°
Seat Tube Angle (Effective) - Low Setting 74.5° 74.5° 74.5° 74.5° 74.5°
Head Tube Angle - Low Setting 68.5° 68.5° 68.5° 68.5° 68.5°
Wheel Base 1084mm 1115mm 1155mm 1177mm 1197mm
Standover Height 721mm 728mm 755mm 764mm 778mm
Head Tube Height 100mm 120mm 140mm 160mm 160mm
Handlebar Width 640mm 640mm 640mm 640mm 640mm
Stem Length 75mm 90mm 105mm 120mm 120mm
Crank Length 170mm 175mm 175mm 175mm 175mm
Seatpost Length 350mm 350mm 400mm 400mm 400mm
TT is measured horizontally from center of HT to center of ST
Replicado por A.CALVENTE
15/02/2008 a las 8:47:00
Replicado el 15/02/2008 a las 8:47:00
SALUDOS.
Replicado por soms
15/02/2008 a las 10:40:16
Replicado el 15/02/2008 a las 10:40:16
en mi opinión por ese precio podrias conseguir algo mejor, ya que specialized pagas la marca, el cuadro es una pasada pero a la hora de los componentes escatiman un poco...
por ese precio puedes tener una bici de carbono rigida con xt, o una doble alumino con xt...
Replicado por NoRTH
15/02/2008 a las 10:48:32
Replicado el 15/02/2008 a las 10:48:32
Cita de soms: es un maquinon, si a ti te a gustado no dudes en comprartela.... en mi opinión por ese precio podrias conseguir algo mejor, ya que specialized pagas la marca, el cuadro es una pasada pero a la hora de los componentes escatiman un poco... por ese precio puedes tener una bici de carbono rigida con xt, o una doble alumino con xt... ![]() |
Totalemente de acuerdo, por ese precio tienes otras marcas con mejores componentes Giant mismamente ... con su sistema maestro, la S se paga cara y ojo que yo soy poseedor de una pero de 2ª mano, ni loco meto 2650 leuros en una Enduro.
SaludotesSs
NoRTH
< < < < compatibilidad de discos
Qué os molesta más el viento o el frío > > > >
