Quiero una de estas dos bicicletas. Mi opinión quizá equivocada es que es mejor la orbea, al menos en componentes, specialized te hará un cuadro duro como una piedra pero los componentes más bien sean sencillitos. Asesoradme vosotros que entendeis del tema. La orbea lleva discos hidráulicos y la specialized v-brake.
Specialized Hardrock Sport
CUADRO: Specialized A1 Premium Aluminum, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger
HORQUILLA: SR Suntour SF10-XCT-V2-MLO, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, mechanical LO, coil/mcu spring w/ preload adj., size-specific spring rates, spring assisted seals
DIRECCIÓN: 1-1/8" threadless, loose ball
POTENCIA: 3D forged alloy, 10 degree rise, 25.4mm clamp
MANILLAR: Alloy riserbar, 25mm rise, 640mm wide, 8 degree back sweep, 7 degree up sweep
PUÑOS: Specialized Enduro, dual compound Kraton, no flange, 131mm
FRENO DELANTERO: V brake, alloy linear pull, 1pc. pad
FRENO TRASERO: V brake, alloy linear pull, 1pc. pad
PALANCAS DE FRENO: Alloy, linear pull
DESVIADOR: Shimano Altus, 34.9mm clamp
CAMBIO: SRAM X-4, mid cage
MANDOS DE CAMBIO: SRAM X4-R trigger
CASETE: SRAM PG-820, 8-speed, 11-32t
CADENA: KMC X8 w/ reuseable Missing Link
PEDALIER: SR SunTour, Octalink spline
PLATOS: 42S x 32S x 22S replaceable
CAJA PEDALIER: Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALES: Steel cage, composite body, 9/16"
LLANTAS: Alex RH, 26", pinned, alloy double wall, CNC sidewalls, 32h front and rear
BUJE DELANTERO: Forged alloy, double sealed, ground race, steel QR, 32h
BUJE TRASERO: Shimano RM30, forged alloy, double sealed, ground race, cassette, 32h
RADIOS: 2mm (14g) stainless
NEUMÁTICO DELANTERO: Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
NEUMÁTICO TRASERO: Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
CÁMARAS: Schraeder valve
SILLÍN: Specialized XC, Body Geometry, 143mm width, front and rear bumpers
TIJA DE SILLÍN: Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
ABRAZADERA DE SILLÍN: Alloy QR, nylon washer
Orbea Sate
Cuadro: ORBEA MTB ALU
Horquilla: SUNTOUR XCM HLO 100 mm.
Plato: PHAETON 150 24x34x42 W/PR
Dirección: 1 1/8 AHEAD BLACK
Manillar: STEEL MTB RAISED
Potencia: ORBEA ALU BLACK MATT
Manetas: SHIMANO ACERA
Freno: SHIMANO BRM-485 DISC
Cambio: SHIMANO DEORE SHADOW
Desviador: SHIMANO TX50
Cadena: SHIMANO Z8
Rueda: HYPNO DP DISC 26 BLACK
Piñon: SRAM PG-830 11-32 8S
Cubierta: KENDA MTB 26x1.95
Pedales: STEEL CAGE
Tija sillin: ORBEA OC-I
Sillin: MATCH LINE
Creado por sergiy0
07/07/2010 a las 19:42:48
Orbea Sate o Specialized Hardrock Sport Creado el 07/07/2010 a las 19:42:48
< < < < dudas con el garmin
Lapierre x control 210 > > > >
