Creado por jumbo323
15/03/2008 a las 13:25:22
specialized stumpjumper FSR comp Creado el 15/03/2008 a las 13:25:22
Replicado por lalolaley
15/03/2008 a las 13:54:52
Replicado el 15/03/2008 a las 13:54:52
Replicado por jumbo323
15/03/2008 a las 23:00:02
Replicado el 15/03/2008 a las 23:00:02
CUADRO All new Stumpjumper FSR M5 manipulated alloy frame w/ ORE TT/DT, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm travel
AMORTIGUADOR Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.25x1.75
HORQUILLA Fox Float 120 RL, 120mm travel, rebound/compression adjust, lock out, alloy steerer
DIRECCION 1 1/8 threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
POTENCIA Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
MANILLAR Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
CINTA / PUÑOS Specialized thin lock on grip, dual density
FRENO DELANTERO Custom Avid Juicy 5 SL, hydraulic disc, 185 and 203mm rotor
FRENO TRASERO Custom Avid Juicy 5 SL, hydraulic disc, 160 and 185mm rotor
PALANCAS DE FRENO Custom Avid Juicy 5 SL, hydraulic disc
DESVIADOR Shimano M581 LX, DMD, top swing, dual pull
CAMBIO SRAM X-9, 9-speed, mid cage
MANDOS DE CAMBIO SRAM X-7, aluminum 9-speed trigger
CASETE/RUEDA LIBRE Shimano HG-50, 9-speed, 11-34t
CADENA SRAM PC-971 w/ Power Link
PEDALIER Shimano A/A/S 2pc custom
PLATOS 22S/32A/44A, 4 bolt 104/64mm
CAJA PEDALIER Shimano M542, 2pc custom for Specialized
PEDALES Crank Brothers Smarty custom for Specialized
LLANTAS DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
BUJE DELANTERO Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
BUJE TRASERO Shimano custom M525SL hub for Specialized, 32h, alloy QR
RADIOS DT Swiss 1.8mm stainless, alloy nipples
NEUMATICO DELANTERO S-Works The Captain 26x2.0, 120 TPI, tubeless ready aramid bead, dual compound
NEUMATICO TRASERO S-Works The Captain 26x2.0, 120 TPI, tubeless ready aramid bead, dual compound
CAMARAS Specialized Ultralite, .6mm, presta
SILLIN Specialized XC MTB, hollow Cr-Mo rails, SL foam
TIJA DE SILLIN 2015 butted alloy, two bolt non-setback, 30.9 x 350/400mm
ABRAZADERA SILLIN Alloy collar w/ QR, 34.9mm clamp ID
NOTAS Protective clear coat, derailleur hanger, reflectors, owners manual
Replicado por JOAN3276
15/03/2008 a las 23:32:59
Replicado el 15/03/2008 a las 23:32:59
Replicado por Pitiklin
15/03/2008 a las 23:33:20
Replicado el 15/03/2008 a las 23:33:20
Replicado por chettos15
16/03/2008 a las 11:02:24
Replicado el 16/03/2008 a las 11:02:24
Replicado por DONBIKE1
16/03/2008 a las 11:08:49
Replicado el 16/03/2008 a las 11:08:49
Replicado por arbolero
16/03/2008 a las 21:28:20
Replicado el 16/03/2008 a las 21:28:20
28/03/2008 a las 18:30:19
Replicado el 28/03/2008 a las 18:30:19
Replicado por balloonman
28/03/2008 a las 19:12:23
Replicado el 28/03/2008 a las 19:12:23
Replicado por pacobe
28/03/2008 a las 19:49:50
Replicado el 28/03/2008 a las 19:49:50
Yo estoy ahorrando para una expert, a por ellos y a disfrutar....
Saludos a tod@s!!!
28/03/2008 a las 19:56:55
Replicado el 28/03/2008 a las 19:56:55
01/05/2008 a las 18:53:20
Replicado el 01/05/2008 a las 18:53:20
01/05/2008 a las 19:03:39
01/05/2008 a las 20:48:21
Replicado el 01/05/2008 a las 20:48:21
Que la disfrutes
01/05/2008 a las 22:15:38
Replicado el 01/05/2008 a las 22:15:38
Replicado por Skiner
01/05/2008 a las 23:48:55
Replicado el 01/05/2008 a las 23:48:55
< < < < Al final lo descubrí yo mismo
¿merece la pena o no una doble? > > > >
