Creado por cytex50
10/12/2006 a las 1:38:04
merida VS specialized Creado el 10/12/2006 a las 1:38:04
peeds 27
Frame MATTS TFS-disc
Color Red
Fork Rock Shox Tora 302 80 Poplock
Rear-shock 0
Derailleur (front) Shimano LX
Derailleur (rear) Shimano XT Top Normal
Shifter Shimano LX radipfire
Brake lever Shimano LX
Brake Shimano LX Disc 180
Chainwheel Shimano LX 44-32-22
BB set attached
Hubs Shimano LX centerlock
Spokes Stainless Black
Rim Alex TD17 disc
Freewheel Shimano HG50-9 11-32
Tire (front) Maxxis RanChero 2.2 Kevlar
Tire (rear) Maxxis RanChero 2.2 Kevlar
Headset M11 Neck
Handle bar XM Pro Flat 600
Stem XM Comp 10
Saddle XM Comp
Seat post XM Comp SB20 27.2
Pedal Shimano M505
o la spceliazed roskhopper com disc con:
Cuadro: New for 07 M4 manipulated alloy frame, butted ORE DT, disc only, forged dropouts w/ replaceable 98954020 derailleur hanger
Horquilla: RockShox Recon 335 SL, 100mm, 32mm alloy stanchions, alloy steerer, disc only, Turn Key damper, lockout w/ rebound adjust, coil spring
Ruedas: Mavic XM 117, disc
Cubiertas: Specialized Fast Trak, 26x2.0", DC, 60TPI, aramid bead
Cambios: Shimano XT
Desviador: Shimano Deore M-530
Manetas de Cambio: Shimano Deore SL M511
Bielas: Shimano FCM-540, Cobra Shape Hollowtech, Octalink spline, replacable rings with alloy outer 44A/32S/22S
Cassette: Shimano HG-50, 9-speed, 11-34t
Pedales: Shimano 505 SPD, reflectors and cleats
Sillín: Specialized Body Geometry, MTB
Tija de Sillín: Specialized alloy micro adjust, 30.9mm
Manillar: Specialized Butted 31.8mm XC Rise, 640mm wide, 8 degree back/6deg upsweep
Potencia: Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise
Dirección: 1 1/8" threadless
Frenos: Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
a ver q me podeis decir pq tengo una merida y las dos me ls ponen a precios muy similares 990 la merida y 999 la specialized. espero vustras respuestas gracias
Replicado por Borison
10/12/2006 a las 11:48:12
Replicado el 10/12/2006 a las 11:48:12
Replicado por crazybiker
10/12/2006 a las 14:47:28
Replicado el 10/12/2006 a las 14:47:28
Replicado por jomaguca
10/12/2006 a las 15:17:38
Replicado el 10/12/2006 a las 15:17:38
Replicado por Skiner
10/12/2006 a las 15:56:20
Replicado el 10/12/2006 a las 15:56:20
He visto personalmente el cuadro que trae y a mi me parece impecable (seguro que el de la Specialized tambien es igual de bueno).
Replicado por oscarbuzo
10/12/2006 a las 17:54:52
Replicado el 10/12/2006 a las 17:54:52
Replicado por Angelinox
10/12/2006 a las 19:58:11
Replicado el 10/12/2006 a las 19:58:11
Yo la Matt la encuentro guapa y robusta, pero es muy pesada ( la de 1150 euros llega casi a los 14 kg!!.)
Por componentes la Matts ( exceptuando la Recon ).
Una Spe es más buena de vender, y en rojo la encuentro preciosa.
P.D. aunque 1000 euros es mucha pasta para los componentes que llevan. La verdad una semi con una Tora 302 por esa pasta'>;´i'>.....aunque la Spe no se queda atrás ( Mavic XM 117 por 1000 euros'>;´i'>).
Replicado por cytex50
10/12/2006 a las 22:05:10
Replicado el 10/12/2006 a las 22:05:10
10/12/2006 a las 22:44:18
Replicado el 10/12/2006 a las 22:44:18
10/12/2006 a las 22:53:56
Replicado el 10/12/2006 a las 22:53:56
Cita de cytex50: entonces los dos cuadros los fabrica merida?por cierto gracias a todos por las respuestas |
efectivamente
11/12/2006 a las 15:30:09
Replicado el 11/12/2006 a las 15:30:09
12/12/2006 a las 16:22:15
Replicado el 12/12/2006 a las 16:22:15
< < < < ¿A conor se le esta llendo la pinza?
v-brake > > > >
v-brake > > > >
